configuring the management port in SupV
mtechnology
Can anyone let me know how to configure the management port present in SupV.
The interface does not seem to exisit when i do a show run.
is there any cisco doc to which someone can point me too
thanks
deepinder
The management port is used for IOS recovery. This port will only be active in ROMMON mode.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/78_16727.html#wp100588
Please rate if this info was helpful.
Deepinder Singh Babbar
Thanks for the info
But the link does not give any information about using the port in case of disaster
Check the below mentioned link that will help u in configuring MGMT Port in case of disaster.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_example09186a0080094ecf.shtml#image
Please Rate if info was helpful.
