Confused with ACL rules on 3750E switches
Matt Dunleavy
Hi all,
I have a 3750E switch in routing mode, with 3 vlans.
I have 2 questions, I have created an ip access group "in", but for it to work have to specify the subnet in the ACL rule, I would have thought it would be the other subnet coming "in"
If I am not making my self clear, sorry here is what works and what doesnt.
This code works:
ip address 172.16.1.1 255.255.255.0
ip access-group ACL2010 in
ip access-list extended ACL2010
permit ip 172.16.1.0 0.0.0.255 any
This is what I think it should be (but doesn't work):
permit ip 192.168.10.0 0.0.0.255 any
Now my second question is, I have a static route to an ASA on vlan 300. However, when I install a PC in this subnet, I do not need any ACL rules, everything flows between both the 192 and 172.16 going to and from the 172.31 even though I haven't defined any rules. Why is this?
Full Config (working):
interface Vlan100
description DMZ
interface Vlan200
description Inside
ip address 192.168.10.1 255.255.255.0
ip access-group ACL1020 in
interface Vlan300
description ASA Vlan
ip address 172.31.0.6 255.255.255.248
ip classless
ip route 0.0.0.0 0.0.0.0 172.31.0.1
ip http server
ip http secure-server
ip access-list extended ACL1020
the confusion might come from the fact that 'in' and 'out' do not refer to source and destination, but to the inbound and outbound interface on the router.
So, 'in' traffic is traffic that has arrived on the interface on which the access list is applied, and, if a match is found, is then permitted to go through the router.
'Out' traffic is traffic that has already passed through the router, and that is leaving the interface on which the access list has been applied..
--> This allows all traffic sourced from 172.16.1 0/24 to anywhere. It is the same as having no access list at all configured.
--> This denies all traffic (due to the implicit 'deny'). If you want to restrict the access to and from only 192.168.10.0/24, you need this:
permit ip 172.16.1.0 0.0.0.255 192.168.10.0 0.0.0.255
deny ip any any
--> the same applies here. The access lists allow everything, and are the same as no access list at all.
Thank you, this makes sense. Which is why the vlan300 works with no issues because by default its allowed.
So this means, that if something other than 192.x is attempting to come through to the port interface it will be blocked right? So as soon as I had set that ACL, only what is permitted on the ACL is allowed - even if I am not using the switch as the gateway?
Say i have 2 machines on the same vlan 100 and they are 10.x.x.x (they don't route via any gateway on the switch, but they communicate on ports on the switch, these would be blocked then?
Hello Matt,
exactly. The access list has an implicit deny, so whatever you do not specifically allow will be denied.
Two machines on the same Vlan will always be able to communicate, since traffic between them would not flow through the layer 3 Vlan interface. If you want to filter traffic between hosts on the same Vlan, you need a VLAN Access List (VACL). The link below gives you an example on how it works
https://networklessons.com/cisco/ccie-routing-switching/vlan-access-list-vacl/
