Connect 2 switch cat6
theaskyme
I m trying to connect 2 catalyst switches as trunk using cat6  crossover cable ( around 30m )
The ports are enabled , the cable is tested and both ports set to trunk :
Catalyst 3650G  & Catalyst 2960
The problem is that , there is no lighting when connected. and both ports stay down.
Do you guys have any troubelshooting / solution for this ?
Thank you for your support.
28 Replies 28
cadet alain
Did you try other ports? Did you try other cable? what is output of sh interface?
Are you just linking 2 ports with a single cable? Can you do a sh run interface
Regards.
Alain.
- I tried 2 cables ( both cat6 , different companies )  and both same result
- I m linking the 2 ports to be used as trunk
- sh run interface :
interface GigabitEthernet0/23
description Connected to roof cat6
switchport mode trunk
end
interface GigabitEthernet0/1
description Connected to Core Switch
end
- the following is the sh interface for both switches :
GigabitEthernet0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is
  Description: Connected to Core Switch
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is Not Present
  input flow-control is off, output flow-control is unsupported
  Last input 3d02h, output 3d02h, output hang never
  Last clearing of "show interface" counters 1w6d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     34740282 packets input, 28095001437 bytes, 0 no buffer
     Received 1227712 broadcasts (0 multicasts)
     149 input errors, 128 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1132553 multicast, 0 pause input
     25094584 packets output, 3462704888 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
GigabitEthernet0/23 is down, line protocol is down (notconnect)
  Description: Connected to roof cat6
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  Last input 3d20h, output 3d20h, output hang never
     5 packets input, 969 bytes, 0 no buffer
     Received 5 broadcasts (0 multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 5 multicast, 0 pause input
     7 packets output, 448 bytes, 0 underruns
     0 output errors, 0 collisions, 12 interface resets
Thank you for your help
The Delay and Bandwidth values are not good, these are the ones for an ethernet port
  Keepalive not set
That's not cool  either.
Could you try on 2 other ports.
Regards.
Alain.
Hey Alain,
It is the same on all ports.
is there anyway to edit ? or reconfigure ,
i tried to set both ports to default using command : default interface
and then reconfigure to trunk.
but with the same result.
the port is not getting up.
Thanks again for your help.
Can you plug a PC in these ports and get connectivity?
Can you try with a cat5 cable.
Regards.
Alain
Hey Alain,
- Cat5 cable works
- I can plug 2 laptops and get 1gb connectivity with ping
- also i just tried to connect f0/48 to g0/23 and it works using the cat6 cable , but when i connect g0/1 to g0/23 no lights, port dont get up
ok,
So now we know the cable is good indeed, the port is functional but there is something  going between these 2 ports when using this cat6 cable.
Can you statically define the duplex and speed setting to full -1 Gig on two interface and see it it is working then.
Regards.
Alain.
I tried to set it from 1 side on the 3650G ( tried the duplex and half duplex and changing speed to 10 & 100 & 1000 with no successs ) , because on the 2960 48ports switch with 2 giga ports , i cant set speed or duplex.
Best Regards,
hi,
ok, the G0/1 is a dual-purpose uplink port
Can you try this : under Gig0/1 enter media-type rj45
Try againg and tell us.
Regards.
Alain.
Thank you alain,
Sorry for the late reply,
I will try this on monday
and will reply with the results.
Hello Alain,
I tried to set media-type rj45 but still i got no lights
Thank you alot for your suggestions.
If you console into the 3560G, run a TDR to determine where the problem is.  Here's how you do it:
1.  Command:  test cable tdr int ;
2.  Wait for about 5 - 7 seconds; and
3.  Command:  sh cable tdr int
Please post the output of the command.
Thank you  leolaohoo, for you reply,
i will try your suggestions on monday.
Any luck?
