connect HP access point to cisco switch
squhospital
i am trying to configure my HP 420 access point. I have configure different  SSID on it,
This access point is connected to cisco 4500 switch, i have configure trunk on up link to  access point.
my problem is the client are not able to get an IP address form the correct vlan if i tagged the SSID to it.
in the following the output of show run int in cisco 4500 switch:
interface GigabitEthernet3/13
description ==== HP ACCess point ====
switchport trunk allowed vlan 99,130,132
switchport mode trunk
switchport nonegotiate
her is the HP Access point configuration
HP ProCurve Access Point 420#sh system
System Information
Serial Number         : AP Ser
System Up time        : 0 days, 0 hours, 31 minutes, 34 seconds
System Name           : OT1
System Location       :
System Contact        : Contact
System Country Code   : OM - OMAN
MAC Address           : AP Mac
IP Address            : AP IP add
Subnet Mask           : 255.255.255.0
Default Gateway       : 10.78.99.1
VLAN State            : ENABLED(Static VLAN ID)
Management VLAN ID(AP): 99 (T)
IAPP State            : ENABLED
DHCP Client           : DISABLED
HTTP Server           : ENABLED
HTTP Server Port      : 80
HTTPS Server          : DISABLED
HTTPS Server Port     : 443
Slot Status           : 802.11g
Radio Status          : Enabled
Software Version      : v2.1.5
SSH Server            : DISABLED
SSH Server Port       : 22
Telnet Server         : ENABLED
Max Telnet Session    : 4
Serial Port           : ENABLED
Reset Button          : ENABLED
SSID Number Supported : 8
Hey,
how looks a "sh int trunk" on the cisco ? and maybe the whole config from the AP, I see no SSID, vlan mapping there?
regards,
Sebastian
