Connect two Catalyst 3750G
informatiquecns
I try to connect two switch Catalyst 3750G without success.
switch1 (192.168.2.10 vlan 2) <=> (192.168.2.11 vlan2) switch2
I use this configuration for swich1 :
enable
configure terminal
enable password MDP
end
copy running-config startup-config
configure terminal
hostname switch1
interface vlan 2
ip address 192.168.2.10 255.255.255.0
exit
ip default-gateway 192.168.2.252
end
configure terminal
vlan 2
name zone_client
end
configure Terminal
interface Gi1/0/3
switchport mode trunk
switchport nonegotiate
switchport trunk native vlan 2
switchport trunk allowed vlan 1,2,3,4
end
I use this configuration for swich2 :
enable
configure terminal
enable password MDP
end
configure terminal
hostname switch1
interface vlan 2
ip address 192.168.2.11 255.255.255.0
exit
end
configure terminal
vlan 2
name zone_client
end
configure Terminal
interface Gi1/0/3
end
when i use ping in console terminal, ping fail.
Somebody can help me?
23 Replies 23
Make a show run int gi 1/0/3 on both switch.
switch1#show running
Building configuration...
Current configuration : 1794 bytes
version 12.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
enable secret *********************
enable password **************************
no aaa new-model
switch 1 provision ws-c3750g-24ts-1u
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
switchport trunk allowed vlan 1-4
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
interface Vlan2
ip classless
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
switch1#
switch2#show running
version 12.2
no service pad
hostname switch2
boot-start-marker
boot-end-marker
enable secret ***********************************
enable password *******************************
no aaa new-model
ip subnet-zero
interface Vlan1
no ip address
interface Vlan2
ip classless
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
I don't think so
Can the OP post the same output for sw1.
switch1>sh int g1/0/3 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 2 (zone_client)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 1-4
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
it didn't take the switchport mode trunk command because you configured it before switchport trunk encapsulation dot1q
so reenter this command switchport mode trunk and it should be good,  I still wonder how I didn't remark that before.
Regards.
Alain
    You need to add "switchport mode trunk" on Gi1/0/3 on both switches.
HTH,
Toshi
i agree... switchport mode trunk on both switch and see if it work.
network_guy
A couple things I would suggest. First I noticed both of your switches are set to VTP Server, if your going to runt Client-Server I would fully configure it (domain and passwod matching). If these two are your only switches as of now I would use Transparent to troubleshoot. Also, where is the IP of the default gateway? Where does your ip default-gateway IP sit? It's not configured on your switches? If these are the only two switches on your network I would put the ip default-gateway as the other switches IP.         Switch 1: ip default-gateway 192.168.2.11
Switch 2: ip default-gateway 192.168.2.10
Thank you Cadet Alain and Thotsaphon for your assistance.
When i add "switchport mode trunk" on both switch, it's work.
The configuration who work :
PC<=>(Vlan 2 in access mode)switch1(vlan 2 in trunk mode)<=>(Vlan 2 in trunk mode)switch2(vlan 2 in access mode) <=> (old swich) <=> (vlan in untagged mode ) HP swich <=> Gateway
But this configuration doesn't work :
PC<=>(Vlan 2 in access mode)switch1(vlan 2 in trunk mode)<=> (vlan in tagged mode ) HP swich <=> Gateway
Joshua.peavy > I not sur that i understand what your need (my level in english is not hight).
The target configuration is the following.
If on sw1 Vlan 2 is the native vlan , it will be sent on the trunk untagged so it must be untagged also on the HP switch or you can force tagging of vlan 2( the native vlan) on the Cisco with the global config command: vlan dot1q tag native
Regards.
Alain
It's work!
Thank you for your assistance.
