09-15-2014 02:52 AM - edited 03-07-2019 08:45 PM
I tried connecting an unmanaged (and dumb) switch to one of the four fast ethernet ports on the back of the router. I configured the port to act as an access port bound to a specific VLAN, say no. 100.
What I can see on the LEDs of the unmanaged switch is that the link goes up and down every few seconds. I don't know if this is related to the spanning tree protocol and unfortunately the unmanaged switch doesn't know about STP and doesn't send out BPDUs.
So, how I should configure the port in order to avoid the link going up and down?
The actual conf. for the port:
09-15-2014 03:11 AM
What do you mean by dumb siwthc? What model/make/company is that switch?
Can you try to do the reset of the switch so that it wipe off all the config what so ever present on the box and then try to connect the switch to the router?
09-15-2014 03:11 PM
It's an unmanaged switch. There's no config. on it. You can buy such h/w at the grocery store.
09-15-2014 03:45 PM
As this is switch to switch set up have you tried a crossover cable or does the dumb switch have a
MIDI/MIDIX uplink button to perform the crossover.
Alex
