Connecting 2 locations with 2 lines
Anand Narayana
Level 6
Level 6
on Location A 3750 & on location B3com layer 3 switch, A & B are connected with two 2 Mbps leased line with ethernet output, now i wanted to load balance or i wanted to use a etherchannel kind of thing, so that even if 1 link goes, the other should still be up & running. how do i proceed.
3750------3com ---connected via ISP1
3750------3com ---connected via ISP2 to the same location. it is a point-to-point link.
15 Replies 15
Anand,
CEF is by default enabled on the 3750 switches.It only supports hardware per destination switching bydefault. If you want to configure it for sw per-packet load-balancing, try configuring " ip load-sharing per-packet " under the L3 interfaces.
HTH,
-amit singh
