Connecting 2 switches while using VLANs
wordizbon
I'm new to this community and am not sure if this is the best place to post this but I'm trying to connect 2 switches and using VLANs in preparation for my CCNA. I set up VTP and it appears to be working well between the Server and Client. I've set up 3 VLANs and each has a default gateway and IP address as below:
Switch 1
VLAN1: IP - 192.168.1.2; Gateway - 192.168.1.1
VLAN2: IP - 192.168.2.2; Gateway - 192.168.2.1
VLAN3: IP - 192.168.3.2; Gateway - 192.168.3.1 802.1q
Switch 2
VLAN1: IP - 192.168.1.3; Gateway - 192.168.1.1
VLAN2: IP - 192.168.2.3; Gateway - 192.168.2.1
VLAN3: IP - 192.168.3.3; Gateway - 192.168.3.1 802.1q
Each have  ports assigned to them and and there is a switch port that is a trunk port connected between the 2 of them. I have no conflict with the native VLAN but I can only ping back and forth between VLAN 1. For some reason VLAN 2 is not able to ping back and forth between the switches.
I have successfully simulated a router on a stick with 1 router/1 switch and proceeded to try an additional switch (switch 2) to see if I could test my knowledge a step further.
Not sure what I'm missing or what I'm doing wrong.
Reza Sharifi
On your trunk port between switch 1 and 2 did you add vlan 2 and 3?
Also, are you using a router to route between vlans 1,2 and 3?  If so the connection between the router and the switch needs to be configured as trunk port with sub-interfaces configured on the router with .1q encapsulation and the gateway addresses (192.168.1.1, 2.1 and 3.1)
Also, can you post relevant config from all devices?
jhager001
Did you setup the router as your VTP Server and your switches blow as VTP clients?
Are you using packet tracer for this? or physical equipment?
