Connecting an AXA Core fax bridge with a Cisco RV325
madmule
Trying to set up a network for a small business.  They have a all in one (scanner, Printer, Fax), a Cannon ImageRunner Advance.  The company that installed it informed the business owners that they need to use a AXA Core Fax Bridge in order to make the fax machine work.  SO what the installers intructed me to do is set up the all in one, connect a CAT5 for the scanner printer to a wall port, and then connect the analog fax cable to the fax bride and connect it to the wall port.  On the router, and here is my problem, they said:
"to allow all traffic outbound through port 443 to IP 64.38.245.109"
and would work.
Well the RV 325 does not have an outbound.  I cannot see a way to make this work.  IF anybody has any suggestions I would greatly appreciate it.
0 Replies 0
