Connecting branch ofices with the HO
manojkumarnb
I want to connect all my 5 branch offices with the headoffice with GBIC ports. Have about 35 systems in my HO. I don't want to use more that 1 switch. Is there any switch available having 48 fast ethernet port and 5-6 Fiber BBIC port.
mohammedmahmoud
Level 11
Level 11
Hi there,
You can use the following link, the closest option is:
Cisco Catalyst 3750 - 48TS
48 Ethernet 10/100 ports and 4 SFP ports
Other wise you shall cascade two of the above switch or you can go for the modular 4500 series.
Cisco Catalyst Switch Guide:
http://www.cisco.com/en/US/products/ps6545/prod_brochure0900aecd80357ff4.html
best regards and HTH,
Mohammed Mahmoud.
