Connecting Netapp FAS2720 with Cisco CATALYST WS-C3650-24TS Denali
lusotik
Hi folks, i have a question for the community
I wanted to plug a Netapp FAS2720  SAN/NAS with some Cisco CATALYST WS-C3650-24TS Denali.
That I see from the Netapp FAS2720 documentation, the connection is SFP+ 10G (10 GbE).
Unfortunatly, I saw from CISCO CATALYST WS-C3650-24TS Denali documentation that we have 4 x Gigabit Ethernet  SFP only.
I wonder if I can anyway plug the 2 devices even we work only with1 GB max network from our infrastructure or must buy a special SFP+ connector for the WS-C3650-24TS?
Many Thanks.
Reza Sharifi
Looking at Netapp documentation, it appears that the network interfaces on FAS-2720 support 1 and 10 gig. If this is the case, you simply need regular 1Gig SFPs for the switch as well as for the Netapp.
https://www.cdw.com/product/netapp-fas2720-4x960gb-ssd-8x4tb-mix/5136971
Also, here is the part number for Multimode SFP.
GLC-SX-MMD
Link:
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/installation/note/78_15160.html
Many Thanks Reza.
