Connecting two Catalyst IOS switches using private-vlan isolated ports
chad patterson
Hello all,
 I am trying to connect two switches together using two ports. Rather than using STP or something, I am trying to prevent looping by implementing private vlans; to isolate the ports from one another.
On Switch #1, I have created two private-vlan isolated ports.
On Switch #2, I connect two access-ports to the Switch #1 isolated ports.
So in theory (my theory), any device connected to Switch #2 should be able to ping any other device connected to Switch #2.  However any device on Switch #1 should not be able to ping any device on Switch #2.
But that is NOT what is happening. Nothing on Switch #2 can communicate with Switch #1, and vice versa. But when I set the ports on switch#1 to be promiscuous rather than isolated, everybody can communicate. But that's not what I'm going for; I am trying to allow only vlan 101 outbound traffic from switch#2 to pass through switch#1.
Can somebody please explain why this not working as I expect it to, and if it is indeed possible to make this work as expected?
chad patterson
I found the answer to the problem.
I was running this simulation in VIRL, and when I changed the Switch#2 to an unmanaged switch, then it worked as expected. So it seems that as long as the switch recognizes PVLAN tagging, then this is not possible.
balaji.bandi
How is the configuration done between Switches.
look at sample configuration and setup as below :
https://www.cisco.com/c/en/us/support/docs/lan-switching/private-vlans-pvlans-promiscuous-isolated-community/40781-194.html
BB
@balaji.bandi: Thanks for posting a link to the page where I obviously got the diagram from.
The configuration between the switches is what the included configuration is in the diagram. The top switch is Switch#1 and the bottom diagram is Swtich#2. I am trying to put the private-vlan isolated ports on Switch#1, and connect the host to switch to Switch#2.
So to sum it all up, I am basically trying to connect two switches together using private-vlan isolated ports.
My question is, why isn't that working? Is it possible to make it work, and if so, how?
chad patterson
