Connection blocked
alliancefp
im a very novice user of an 857w; hoping someone can help me with what i would assume a very basic solution...
I have recently upgraded to a Cisco 857w nad trying to set up for general internet useage, QoS & Firewall etc i'll nut once i can get the net in general working...
I've done the general setting to connect to my ISP (they can see the connection on their end) but i cannot ping anything out of my local network or access any websites. I have a Dynamic IP, only 1 PC connected via ethernet.
In the 'configure' area of the SDM (v2.5 IOS 12.4(15)T3) for the VLAN and the ethernet ports there are no IP addresses assigned. Ive tried testing the connection using the SDM, DNS passes but IP address cannot/is not assigned.
Any help here would be great & much appreciated.
Marwan ALshawi
can post ur ur config
on the router simply do
show run
then past it here
