Connection dropping with regular interval
bennychenmathew1966
Community Member
      The connections on all switches dropping intermittently . Users are disconnected in the middle .Amost all the 60+ stack has same issue..
See the attachment . The same issue on all the swithches
Any help will appreciate
Pat Kinnison
Visitor
You switch is managing broadcast storms on your network. Storm control, or traffic suppression, monitors packets passing from an interface to the switching bus and determines if the packet is unicast, multicast, or broadcast. The switch counts the number of packets of a specified type received within the one second time interval and compares the measurement with a pre-defined suppression-level threshold.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SXF/native/configuration/guide/swcg/storm.html#wp1039559
