Bookmark
Subscribe
729
connection router to router
bkoum
hello
is it possible to connect a router with another router using the fastethernet ports ?
thanks
Nagendra Kumar Nainar
Yes, you can connect routers directly using FE ports. You need to use cross cable if the platform doesnt support auto-MDIX feature.
HTH,
Nagendra
HTH,
Nagendra
sohailian
Yes ofcourse u can connect!
Sohail Akhtar
sohailpk.blogspot.com
