10-22-2014 05:01 PM - edited 03-07-2019 09:13 PM
We are connecting a remote warehouse to corporate office through wireless radio controllers. we connected corporate office controller to a 3750 and configured the port as trunk. we connected the remote controller to a new 3850 switch. we are unable to ping radio controllers or switches. Any help would be greatly appreciated.
10-22-2014 05:24 PM
Is the link between the 2 devices up and running?
Did you configure the link on both 3750 and 3850 as trunk?
Can you post configs from both devices?
10-22-2014 05:30 PM
when I was connected to the wireless controller directly, I was able to ping them both so the connectivity between controllers is good. I think issue is on the switch side.
Config for the trunk port on 3750 is
LAN-B55-F3-R325-SW01#sh run int g1/0/1
Building configuration...
Current configuration : 348 bytes
interface GigabitEthernet1/0/1
description *** Connection to Radio Controller ***
switchport mode trunk
switchport nonegotiate
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust dscp
auto qos trust dscp
storm-control broadcast level 50.00
storm-control multicast level 50.00
end
10-22-2014 05:35 PM
Yes I created both links as trunk on 3850 and 3750.
Config for 3850 trunk port is as follows
| interface GigabitEthernet1/0/48 |
| description *** Connection to Radio Controller *** |
| switchport mode trunk |
| storm-control broadcast level 50.00 |
| storm-control multicast level 50.00 |
| auto qos trust dscp |
10-22-2014 06:08 PM
The switches are just layer-2 with no IPs. So, if there is no IP an the switches you can't ping them but if you can ping from one controller to the other through the switches than the connectivity is good.
The trunk configs are correct.
10-22-2014 06:28 PM
I am not able to ping controllers from the either switches.
10-22-2014 07:08 PM
But do the switches have any IP configured on them?
If the switches don't have IPs you can't ping from them.
10-22-2014 05:39 PM
Interface is showing up up.
LAN-B55-F3-R325-SW01#sh int g1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is d48c.b596.c501 (bia d48c.b596.c501)
Description: *** Connection to Radio Controller ***
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 363
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 10000 bits/sec, 18 packets/sec
5 minute output rate 86000 bits/sec, 135 packets/sec
514671015 packets input, 73497025643 bytes, 0 no buffer
Received 1085394 broadcasts (366403 multicasts)
0 runts, 2 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 366403 multicast, 0 pause input
612703588 packets output, 91643874369 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
