Console Connection Without DB-9 or DB-25 Port in PC
MA Khatri
I have new PC with Intel Core 2 Quard Processor and Intel DG43NB Board. Unfortunately the board has no DB-9 or DB-25 port for console connection to Cisco Router or Switch.
Then how can I make console Connection to the router or switch?
May I use some type of adapters for console connection through my USB Ports? If yes then which one ?
cadet alain
yes you can use a usb to serial adapter and choose the one that is working on your OS version.
Regards.
Alain.
cadet alain
Regards.
Alain.
