console framing error
kristiant
When i boot up my 1720 router i get this message: console framing error
and i cant enter the cli but pressing break to enter rommon works
Any ideas
Kristian
Giuseppe Larosa
Hello Kristian,
verify the console cable you are using on another device it could be faulty
verify your serial port settings
they should be 9600 bps 8 bit 1 bit stop no parity flow control none
try to telnet to the router instead of sending it in ROMMON (you may need a cross-over ethernet RJ45 cable)
Hope to help
Giuseppe
after searcing awile on the net i probaly found the solution. The problem isnt the cable ore the connection setting on the port
but rather that i use a x64 and a usb-serial adapter. Booted up an old xp pc and i worked straith away
Hello Kristian,
interesting to know that Windows XP 64 bit + usb to rs232 adapter can be a problem for console connections to cisco routers
Best Regards
Giuseppe
after some further diging i found out this isnt the x64 os same thing happend when i used the rs232 adapter in the old Pc, when i got it working i just used the com port and not the adapter, sry being abit in the rush there to blame the os ;). But its not the adapter itself to blame either since i use it to configure several types of alarm systems and Nortel switches whitout any issue
