Console into 3845Rt instead of Switch module??
CiscoBrownBelt
Level 6
Level 6
I did a service-module reset and password-reset because enable password would not work (still would not work, had to get TACACs up to login) and now when I console directly into the console port, I am in the switch module (NME-X-23ES-1G-P) and not the actual 3845 router. No service-module commands work on the switch module, only on the router. I am not sure what commands I enter to fix this. Does anyone know? My options on the router are:
service-module g1/1 ?
heartbeat-reset
password-reset
reload
session
shutdown
statistics
status
amikat
Will you please try the command "service-module g 1/1 session clear" from the router.
Best regards,
Antonin
5 Replies 5
Reza Sharifi
Press Ctrl-Shift-6, then release all keys, and press x.
So I console into it (switch module since it does not console into router) and do those commands? I do that but it does not do anything. I SSH to the router which works, and tried it but nothing.
When you are in the switch module, what is the output of "sh session"?
amikat
Best regards,
Antonin
That worked thanks!
