Console links state alerts not showing
sdaniels44
This is probably an easy question.
When i issue a terminal monitor command on a cat 6500, I am not getting info on link state changes.
ex.
%LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
%LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to down
I can not see anything using "debug interface ?" that jumps out as the obvious answer. Any ideas?
Thanks.
5 Replies 5
cisco_lad2004
Level 5
Level 5
do u have snmp trap link-status configured under interface ?
SNMP needs to be activated in some cases, like this one.
Sam
This has to be done for each interface?
That was it. Thanks for your help.
you're welcome..thanks for the points...
