Control Plane Security Configuration
JohnTylerPearce
Level 11
Level 11
Hey guys, I was looking for some advice about configuring the control plane to mitigate DoS attacks. I understand you can use
MQC and apply it inbound and or outbound to the control plane, I just couldn't find any examples of configuring it to prevent and
mitigate DoS attacks. Or some recommended practices for this sort of thing. Like the recomended setting for policing TCP etc.
I know this depends on someone's specific setup, but was just looking for a pointer or two.
A good starting point is the "Cisco Guide to harden IOS devices":
http://www.cisco.com/en/US/partner/tech/tk648/tk361/technologies_tech_note09186a0080120f48.shtml#cplane
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Ganesh Hariharan
Hello ,
Check out the below link which basically talks about control plane security ....
http://www.cisco.com/en/US/docs/ios/sec_control_plane/configuration/guide/sec_control_plane_overview.pdf
Hope to Help !!
Ganeshh Iyer
Rate if it Helps...
Thanks for the help guys.
