Convert CatOS running-config to Native IOS running-config
Jason Aarons
Level 6
Level 6
Is there a tool on CCO to convert the running-config under CatOS to a Native IOS running-config?
Doesn't run in Vista.
The online tool available at cisco.com was removed once this program was made available. I won't recommed you to do it "by hand" since it will be time consuming therefore finding a non-Vista computer might be the way to go here.
