Converting Regular VLAN to Private VLAN
csaravanan-sym
We have regular vlans configured on our switches. We now have a requirement to segregate one of our VLAN to a private VLAN.
If we have to convert the regular VLAN to a private primary VLAN and then create secondary VLANs beneath it. Will the existing inter-vlan communication be affected. once changed will the private-primary vlan be able to communicate to other regular VLANs as before
Also what are the other issues I need to be aware of if I convert a regular VLAN to a private primary VLAN
Chandru
Yudong Wu
Level 7
Level 7
Private vlan is used for partitioning the Layer 2 broadcast domain. It should not impact inter-vlan communication since they will go through layer 3 interface.
Please refer to the following link for the config guideline and restictions.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/pvlans.html#wp1142959
