Copy file from a container to usbflash
Hello all,
i'm new with containers and i've installed a container on a C9300L to monitor my connectivity.
My question is: Is it possibile to copy one file from a container folder to the usbflash installed in the switch?
I would like to create a copy of the container's database file on the switch usb
I know that i can copy from the switch to the container files but i cannot find the way to do it viceversa.
Many thanks in advance
Leo Laohoo
copy bootflash:filename.ext usbflash0:
this is not what I meant.
I have to copy the file from the /data/SpeedTest path of the container to the switch.
The docker equivalent would be "docker cp" but I only found the way to copy from the switch to the container and not to the reverse
