copy flash tftp command failed on Cisco 3750 switch
Nabaruma
I have a cisco 3750 swicth which i want to load a new ios to but unfortunately there's no enough space on the flash. This means that i need to backup the cureent (old) ios to my tftp server but the command keeps failing. It always gives 'No such file or directory' error .
The free space on the flash is 8mb and my new ios is about 11mb.
I also went inside the directory where the old is and inputed the same copy command but to no avail.
Below are some of the command failure on the swicth:
VNPSWITCH#sh flas
Directory of flash:/
    2  -rwx           5   Mar 2 1993 16:31:57 +00:00  private-config.text
    4  -rwx        1336   May 7 1993 02:07:25 +00:00  vlan.dat
    5  drwx         192   Apr 4 1993 04:36:26 +00:00  c3750-ipbase-mz.122-25.SEB
  363  -rwx        3919   Mar 2 1993 16:31:57 +00:00  config.text
15998976 bytes total (8884736 bytes free)
VNPSWITCH#copy fla
VNPSWITCH#copy flash tf
VNPSWITCH#copy flash tftp:
Source filename flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin
Address or name of remote host []? 172.19.2.214
Destination filename [c3750-ipbase-mz.122-25.SEB4.bin]?
%Error opening flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin
(No such file or directory)
Please assist.
Usman.
32 Replies 32
jhosa_reddy
Source filename flash:/c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin
Yes I got the same problem, but later I fixed it this way
  Do sh version first and copy the IOS path like:- flash:/c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin
Issue the command :- copy flash tftp:
When asking for source file name past the same u copied
Rest of the things will be same
Buckler.joseph
You are attempting to copy a directory instead of a file. 3750s wont allow this behavior.
Instead try the following:
switch#cd flash:c3750-ipbase-mz.122-25.SEB
switch#show flash
switch#copy flash:(file name) tftp:
to back out of directory:
switch: cd ..
Cheers
