copy flash tftp command failed on Cisco 3750 switch
Nabaruma
I have a cisco 3750 swicth which i want to load a new ios to but unfortunately there's no enough space on the flash. This means that i need to backup the cureent (old) ios to my tftp server but the command keeps failing. It always gives 'No such file or directory' error .
The free space on the flash is 8mb and my new ios is about 11mb.
I also went inside the directory where the old is and inputed the same copy command but to no avail.
Below are some of the command failure on the swicth:
VNPSWITCH#sh flas
Directory of flash:/
    2  -rwx           5   Mar 2 1993 16:31:57 +00:00  private-config.text
    4  -rwx        1336   May 7 1993 02:07:25 +00:00  vlan.dat
    5  drwx         192   Apr 4 1993 04:36:26 +00:00  c3750-ipbase-mz.122-25.SEB
  363  -rwx        3919   Mar 2 1993 16:31:57 +00:00  config.text
15998976 bytes total (8884736 bytes free)
VNPSWITCH#copy fla
VNPSWITCH#copy flash tf
VNPSWITCH#copy flash tftp:
Source filename flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin
Address or name of remote host []? 172.19.2.214
Destination filename [c3750-ipbase-mz.122-25.SEB4.bin]?
%Error opening flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin
(No such file or directory)
Please assist.
Usman.
32 Replies 32
Can you do a dir command in each folder so it shows what is in each directory?
Hello Guys,
I still ca't locate the file (.bin) in the switch. I have changed directroy to flash:c3750-ipbase-mz.122-25.SEB4 but still can't find the file.
How do I locate this .bin file? I guess if I can locate it I would be good to go.
Guys, please don't give up.
Help out.
Usman,.
Rodrigo Curado
Hello Usman,
Did you tried 'archive upload-sw'?
Anyway I think you are typing the filename wrong, actually the path name.
Try one of these two:
1)
copy flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin tftp:
2)
copy flash tftp:
when asked about the source filename just type:
What I'm seeing from your copy & paste looks like you are typing
On the other hand... could just be my eyes tricking me.
Nabaruma
Hello Guys,
Help out.
Usman,.
Can you do an dir  flash:c3750-ipbase-mz.122-25.SEB4 and see what the output is. The only thing I can think of is your image file name isn't what your typing in. So dir the directory and see what the image name is in the directory.
Hi Andersen,
Below is the command you asked me to try and see the result below;
VNPSWITCH#cd flash:c3750-ipbase-mz.122-25.SEB4
VNPSWITCH#dir
Directory of flash:/c3750-ipbase-mz.122-25.SEB4/
    7  drwx        4032   Mar 1 1993 00:05:49 +00:00  html
  362  -rwx         579   Mar 1 1993 00:06:15 +00:00  info
    3  -rwx     5508786   Apr 4 1993 04:29:47 +00:00  c3750-ipbase-mz.122-25.SEB
VNPSWITCH#
You can see there's no .bin file in that directory. The question is where else is that file be found?
Thanks for your effort.
Usman
Hello Usman,
That's strange, when you do the dir command you shoud see the bin file.
Please, do the show version command just to see what is the correct name of the bin file that is used as a system image file.
Tiago
Hello Tiago,
Below is the sh version command on the swicth.:
VNPSWITCH uptime is 6 weeks, 2 days, 2 hours, 52 minutes
System image file is "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.S
EB4.bin"
I believe the system file name is the same with what we have been trying all this while. How do we locate this .bin file is the big question now.
Usman.
I guess the file you are looking for is there, without the .bin extension but it's there.
Could you have done something before that renamed the file?
Anyway, download it and compare its MD5/SHA with the original (not the IOS combined with the web files). As far as I remember you can get that hash from cisco.com.
Also, if you already know the IOS version that you are currently running, download it from cisco.com and keep it as a backup.
Cheers,
Hello Dear,
That was a nice one from you!
I tried the copy command from the dir flash:c3750-ipbase-mz.122-25.SEB4 and it worked fine.
I guess as you said the .bin extension was modified on the image file and that was why I could not see it in all the directories.
In the command I only added .bin when asked the "destination filename" as you can see in the command below.
Below are the command i tried in the solving this problem.
I really appreciate you all guys!
VNPSWITCH#sh flas
VNPSWITCH#copy flash:c3750-ipbase-mz.122-25.SEB4 tf
VNPSWITCH#copy flash:c3750-ipbase-mz.122-25.SEB4 tftp:
Destination filename [c3750-ipbase-mz.122-25.SEB4]? c3750-ipbase-mz.122-25.SEB4.
bin
5508786 bytes copied in 23.085 secs (238631 bytes/sec)
VNPSWITCH#
Have a nice time all.
Usman.
Usman don't forget to check the MD5/SHA hash just to be on the safe side.
Cheers,
Hello Rodrigo,
Actually what I wanted to do was just backup (because of space issue) this ios on the switch so that I could download a crypto ios from cisco and upload on the swicth.
But , I don't know why do I need compare MD5/SHA with the ios's? Do I need to compare it with this my new crypto ios? And how do I do that?
Usman
You would compare the MD5 to verify the file is correct and unmodified (someone correct me if I'm wrong). But since you've backed up the IOS now all you should have to do is delete the directory (router#del /force /rec flash:directoryname and then create a directory that you want to put the image in and tftp it over (mkdir flash:/directoryname then copy the image to the directory copy tftp: flash:/directoryname) change the boot image and you should be good to go.
Just a stupid question...have you tried to make a reload on the switch? I believe that he goes to rommon. It seems like someone delete the file. It should appears...
Tiago
  you don't need to do a check , a check is done at the end of the file copy
anyway.  If you are using a .bin file to copy just copy it into flash and it
will show up as a .bin file.  If you are using a .tar file then you have to use the archive command to extract th
e files and it will automatically create a new directory with the .bin file in
side the directory , only the directory will show up in flash not the .bin fil;e.
