core layer switch - Load balancing Traffic - Advantage
Yasmeen
Hi Team,
  •  I Have plan to Buy Cisco SG550X-28 28-Port Gigabit Managed Switch - core layer switches for my small office,
  • One switch is enough to buy for core layer
  • and this one switch can support Load balance traffic
  • pls suggest me for load balance traffic related issues in core layer switch
Giuseppe Larosa
Hello Yasmeen,
you can perform load balancing at OSI layer 2 using a port channel or at OSI layer 3 (IP) using equal cost multi path ECMP.
in both cases load balancing will be flow based: a specific flow with a source IP address A.B.C.D and a destination E.F.G.H will use a single physical link in outgoing direction.
So the advantages of load balancing are clear when you have multiple traffic flows with a variety of source and destination addresses.
Hope to help
Giuseppe
Thanks Giuseppe Larosa
