Core Switch showing error message for DFC card
HCL Support
We have one Core Switch model cisco WS-C6509 and we are gtting the error message continue regarding the DFC card.
Error:-% PF_ASIC-DFC1-3-ASIC_DUMP
Error:- %EARL-DFC1-2-SWITCH_BUS_IDLE: Switching bus is idle for 5 seconds
As per show module output the  DFC card  is the sub-module part for the module at slot 1,
CoreSwitch-1#sh mod
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAD1135009H
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1418GUG5
3 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL145028ED
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6700-DFC3BXL SAL11413MLC 5.3 Ok
2 Centralized Forwarding Card WS-F6700-CFC SAL1416FPM5 4.1 Ok
3 Centralized Forwarding Card WS-F6700-CFC SAL14491KJ3 4.1 Ok
Also there is s/w reset showing in show version output,
CoreSwitch-1 uptime is 2 days, 18 hours, 5 minutes
Time since CoreSwitch-1 switched to active is 2 days, 18 hours, 4 minutes
System returned to ROM by s/w reset at 05:36:20 GMT Sun Jul 8 2012 (SP by power-on)
System restarted at 05:38:19 GMT Sun Jul 8 2012
System image file is "disk1:s72033-ipservicesk9-mz.122-18.SXF17.bin"
Suggest me on this case as this is Core Switch and most critical from Customer end.
Also attaching here show module, show diagnostic result module, show tech-support for the Switch.
Ashutosh
Giuseppe Larosa
Hello Ashutosh,
try to reseat the linecard in slot 1 in a maintenance time window
If after this the problem is not solved open a TAC request to make an RMA of the affected DFC.
It may happen that a DFC fails.
Hope to help
Giuseppe
Sandeep Choudhary
HI Ashutosh,
The "%EARL-2-SWITCH_BUS_IDLE: Switching bus is idle for [dec] seconds" error message in Catalyst 6500/6000 series switches
Core issue
The default syntax is:
There are messages similar to this error message that appear in the logs:
This message indicates that the Encoded Address Recognition Logic (EARL) did not switch any packets on the EARL bus. A recovery mechanism attempts to fix the problem. The system reloads if the problem cannot be corrected.
Resolution
If this error message appears after you install a new module, re-seat the module and check for errors.
Refer to the EARL Messages section of Message and Recovery Procedures for more information.
If possible please set up the diagnostics to complete and then reseat module
on slot 1
Step 1:
C6509_Sup720#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
C6509_Sup720(config)#diagnostic bootup level complete
Step 2:
Reseat the module
Capture the 'C6509_Sup720#show diagnostic result module X(x denotes the module number)
See if the errors re-occur.
link for the EARL Messages section of Message and Recovery Procedures:
http://www.cisco.com/en/US/customer/products/hw/routers/ps368/products_system_message_guide_chapter09186a008069a77b.html#wp1255620
Rate if it helps.
