Correct Gigabit Ethernet Mini-GBIC SFP Transceiver to use with a Cisco 2960X
gary.beasley1
Hi All, I have two 2960X Cisco Units...
(1)Cisco 2960X 24 Port GIGE 4X SFP LAN Mfg. Part No. C2960X-24TS-L
(1)Cisco 2960X 48 Port GIGE 4X SFP LAN Mfg. Part No. WS-2960X-48TS-l
I need to connect the units via Multi Mode Fiber and I have both the Cisco MGBSX1 units and the GLC-SX-MM 1000Base-SX SF Cisco Competitive Manufacturer C2G Part No. GLC-SX-MM 1000Base-SX SFP Fiber LC MINI-GBIC - Cisco Compliant Transceiver
I have had no luck using either of the unit types to make a successful Fiber Connection... can anyone tell me are either of these units compatible or do I need to get another Transceiver to make the Fiber Connection?
Philip D'Ath
You want to use this part number (Genuine Cisco):
GLC-SX-MMD=
Don't waste your time with third party or counterfeit SFPs.
Thanks Philip D'Ath - your answer is much appreciated !
