CPU HIGH "IP INPUT"
I had a problem with my switch C3750G, I just configured some basics command and then the cpu process went to 98%.
The configuration that I made was:
vlan 612
interface Vlan612
ip address 172.19.132.1 255.255.255.240
interface GigabitEthernet1/0/24
switchport trunk allowed vlan 75,221,501,551,612
switchport mode trunk
And after I did that configuration the cpu went high. the only thing that I saw in the log was vlan 221 is up. then I erase all the configuration that I did it before, but still same, I was looking for a loop or a lot of traffic but I didnt find it. the traffic was in 20M.
After I check all the log and the interface, I just turned off the switch and when it restarted it work ok.
Can anybody tell what happened it?
best regard
Paolo Kobashikawa
joonyounglee
hi
my name is JooN Young LEE.
You try "CPU mirroring"
You will find the right cause.
