CPU Load Catalyst 3750
keynet
Level 2
Level 2
Hello
I have a Catalyst 3750 Stack with four switches. The highest load peaks on this stack goes between 70% to 80%. This happends two or three times in 72 hours.
On this stack is EIGRP aktiv with uplinks to 11 other EIGRP switches. For voip is QoS configured.
Is a this CPU utilisation in a normal range?
Pascal
daniel.bowen
Level 5
Level 5
Hi Pascal,
No this is way to high - have a look at the break down on processes when you type the "show proc cpu" command, and see which is claiming the most CPU.
Cheers,
Dan
