CPU utilisation 95 %
Suneelkumar V R
Community Member
Hi All can you please let me know what is this process
40 1859338560 681519081 2728 17.57% 16.50% 16.60% 0 Cat4k Mgmt HiPri
41 6416320402177719280 294 62.21% 62.56% 61.73% 0 Cat4k Mgmt LoPri
why this is taking high CPU due to this my switch causing 95% utilisation and  users are experiencing slowness
please help how to rectify this
Suneelkumar
Reza Sharifi
Have a look at this document on high CPU on the 4500 series.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/65591-cat4500-high-cpu.html
One of the module was having the issue we have shutdown the ports in the module
Now its fine.
thanks
suneelkumar
Austin Sabio
Level 9
Level 9
The proper way is to troubleshoot this by identifying the specific process within Cat4k Mgmt HiPri and Cat4k Mgmt LoPri using show platform health.
"This show processes cpu output shows that there are two processes that use the CPU— Cat4k Mgmt HiPri andCat4k Mgmt LoPri . These two processes aggregate multiple platform-specific processes which perform the essential management functions on the Catalyst 4500. These processes process control plane as well as data packets that need to be software-switched or processed.
In order to see which of the platform-specific processes use the CPU under the context of Cat4k Mgmt HiPri and Cat4k Mgmt LoPri , issue the show platform health command."
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/troubleshooting/cpu_util.html
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/65591-cat4500-high-cpu.html.
Sidenote: Make sure following are disabled.
no ip mask-reply
no ip redirects
no ip proxy-arp
Please rate, if helpful
Thank you.
