CPU Utilization OID for 6509 IOS Core Switch (Running VSS)
Hussein Rasheed
Dears,
i have been trying to collect CPU Utilization via SNMP for our Core Switch, which is Cisco 6509 running IOS, with no luck. I have tried many OIDs shown below but failed. will you please advise of where i can get the correct OID?
1.3.6.1.4.1.9.9.109.1.1.1.1.x
1.3.6.1.4.1.9.2.1.x
#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASE-M), Version 12.2(33)SXI4a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 16-Jul-10 19:51 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
CORE uptime is 2 weeks, 4 days, 12 hours, 41 minutes
Uptime for this control processor is 2 weeks, 4 days, 12 hours, 41 minutes
Time since CORE switched to active is 2 weeks, 4 days, 12 hours, 38 minutes
System returned to ROM by reload at 00:30:31 UTC Fri Dec 10 2010 (SP by reload)
System image file is "sup-bootdisk:s72033-ipbase-mz.122-33.SXI4a.bin"
Last reload reason: Reason unspecified
cisco WS-C6509-V-E (R7000) processor (revision 1.0) with 983008K/65536K bytes of memory.
Processor board ID FOX1420GGA5
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
46 Virtual Ethernet interfaces
178 Gigabit Ethernet interfaces
28 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Rgrds,
Hi ,
last 1 minute 1.3.6.1.4.1.9.9.109.1.1.1.1.7.1
last 5 minutes 1.3.6.1.4.1.9.9.109.1.1.1.1.8.1
Tested
Also have a look on SNMP Obj Navigator.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.109.1.1.1.1.8#oidContent
Dan
Hi ,
Tested
Dan
i am still receiving a test failed when i try to use them
Can you paste the snmp config of the equipment ( including the access-list if there is one )
Also , is there any query for this equipement valid ( are you receiving any reply for any query ) ?
Dan
turned out the snmp community string was removed, the OID u sent are working just fine. thx
