CPU Utilization spikes because of SNMP
edideleon
Hi everybody,
Please help me regarding this issue. Here is the output of sh proc cpu sorted and sh proc cpu history of our WS-4507R-E switch:
CPU utilization for five seconds: 91%/5%; one minute: 40%; five minutes: 34%
PID Runtime(ms)   Invoked     uSecs   5Sec   1Min   5Min TTY Process
233   304681917 308562217       987 25.43% 4.88% 2.31%   0 SNMP ENGINE
55   584412318 768493491       760 19.11% 6.48% 5.36%   0 Cat4k Mgmt LoPri
231   239737293 645600647       371 16.23% 3.12% 1.44%   0 IP SNMP
54 13709806883238751922         0 11.75% 15.95% 16.19%   0 Cat4k Mgmt HiPri
112   151778175 870249780       174 4.79% 1.43% 0.99%   0 IP Input
232   50926702 299389388       170 3.83% 0.73% 0.33%   0 PDU DISPATCHER
119   295710628 159743769       1851 2.63% 2.89% 2.90%   0 Spanning Tree
169       1668     1555       1072 0.47% 0.12% 0.16%   1 SSH Process
224     7832766 825106774         9 0.47% 0.46% 0.47%   0 HSRP Common
39   43630872 13644909       3197 0.31% 0.30% 0.31%   0 IDB Work
160   18204710 27129051       671 0.23% 0.23% 0.23%   0 CEF: IPv4 proces
61   29723343 458703736         64 0.23% 0.18% 0.16%   0 Net Input
14   34903110 68848783       506 0.23% 0.24% 0.24%   0 ARP Input
94     2077032 136439559         15 0.15% 0.15% 0.15%   0 UDLD
228     7696184 38426385       200 0.07% 0.12% 0.11%   0 PIM Process
238     245865   6797420         36 0.07% 0.00% 0.00%   0 System polling
155     8125570 42481026       191 0.07% 0.03% 0.02%   0 DHCPD Receive
229     1731910 138911719         12 0.07% 0.06% 0.07%   0 Mwheel Process
146     3347006 14782912       226 0.07% 0.02% 0.00%   0 IGMPSN
225   10747554 124967994         86 0.07% 0.06% 0.07%   0 HSRP IPv4
227     5061608 22731624       222 0.07% 0.05% 0.05%   0 IGMP Input
22     163999 13584528         12 0.00% 0.00% 0.00%   0 IPC Mcast Pendin
21       20859   2725488         7 0.00% 0.00% 0.00%   0 IPC Event Notifi
24         16         3       5333 0.00% 0.00% 0.00%   0 IPC Session Serv
23       3456   227177         15 0.00% 0.00% 0.00%   0 IPC Dynamic Cach
20           0         1         0 0.00% 0.00% 0.00%   0 IFS Agent Managev
Your help will be highly appreciated.
Thanks in advance!
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The 4500 CPU isn't normally much involved with packet forwarding, the high CPU utilization shouldn't have much, if any, of an adverse impact.  For other control plane processes that do need to share the CPU, hopefully SNMP processing would be of lower priority, and if so, shouldn't adversely impact them either.
If you want to reduce the CPU demand because of SNMP, you'll need to see what the NMS is doing.  Changing the NMS to be more selective in its queries can reduce the SNMP's impact to the targeted device.
esomarriba
Level 5
Level 5
Hi Edison,
I agree with Joseph, go back to your monitoring software and check the polling settings for this particular device. I had this issue with SolarWinds and CiscoWorks, we had to set lower timers for the interval polling agents.
HTH,
/Elyinn.-
esomarriba
Level 5
Level 5
Hi Edison,
Do you have an access-list for your SNMP community string?
Yes I do have an access-list for our SNMP community string. Actually, we have a total of 2 community strings in our switch.
