CRC errors
danny9797
Hello all,
Do CRC errors get cleared every router reboot? I would just like to verify, I see 200 crc errors on my box which has been running for 5 weeks...
thx
purohit_810
Level 5
Level 5
Yes.. Statastics goes to clear on each and every reboot..
It should be reset.
Dharmesh Purohit
Jagdeep Gambhir
Level 10
Level 10
Danny,
Yes, all the interface stats get cleared on reboot.
200 CRC in 5 weeks is nothing to worry about. You can ignore it.
Suggestion : Issue command clear counters , it will reset interface stats and see that frequency of the CRC error
JG
Thanks a lot guys
You welcome Buddy..
Dharmesh
