Create 500 VLANs
rhr
What is the easiest/best way to create 500 vlans on a 3650 switch?
If they are discontiguous you will have to add commas and dashes on a single line, However if you need VLAN 2-501 (VLAN 1 is already created) then you should be able to enter the command:
conf t
vlan 2-500
exit
For discontiguous vlans I believe its:
conf t
vlan 2,5,6-10,23
exit
If its an emulator type device you also may not have those commands.
-David
rhr
I should have mentioned fastest also, is there a script or macro?
conf t
vlan 2-500
exit
conf t
vlan 2,5,6-10,23
exit
-David
Thank you
