create DHCP reservations using MAC addresses
mvoss
How do I create DHCP reservations on a 1700 router using IOS 12.2? I just need to reserve about 6 IPs using MAC addresses.
pkhatri
Level 11
Level 11
Try the following:
service dhcp
ip dhcp pool host1
host 192.168.1.2 255.255.255.0
client-identifier xxxx.xxxx.xxxx ! put your MAC address here
default-router 192.168.1.1
You will need to configure one DHCP pool per client. So you will end up with 6 pools altogether. Specify the MAC address of each host and the associated IP within each pool...
Hope that helps - pls rate the post if it does.
Paresh
pkhatri
Level 11
Level 11
Try the following:
service dhcp
ip dhcp pool host1
Paresh
thanks for your help, that is exactly what I needed.
