Creating a channel-group
dwilli337
I am trying to create a channel-group so that I can use 4x1gig connections from a 3560-x to my core a 4507r.  When i set the ports the 3560 shows them as suspended.  here is the sh run from the ports.  I know that I have gi1/4 on the 3560 shutdown right now and I only have one of the prots cabled right now while I try to get the config working.  Thanks!
3560-x
Building configuration...
Current configuration : 168 bytes
interface GigabitEthernet1/4
description Uplink to CORE GI3/45
switchport mode trunk
shutdown
channel-group 14 mode on
end
Core 4507R
CoreSw# sh run int gi3/45
Current configuration : 172 bytes
interface GigabitEthernet3/45
description UPLINK to Cisco3560DevSwitch GI1/4
end
Also make sure the encapsulation and native vlan is same at both ends.
See the below example configs on my 4507.
interface Port-channel1
switchport
switchport trunk native vlan 50
interface GigabitEthernet3/30
description xxxxxxxxxxxxxxx
channel-group 1 mode on
interface GigabitEthernet3/31
Hope this will help you.
Please rate the helpfull posts.
Naidu.
5 Replies 5
andrew.prince
Level 10
Level 10
Everything MUST be the same @ both ends of the link speed/duplex etc.  Also you cannot bring an EtherChannel up unless both sides are up/up!
HTH>
Both ports are set to auto/auto for duplex and speed.  They both show a-full and a-1000.
I set duplex full and speed 1000 on both prts then did a shut/no shut on each and they come up as suspended.
switchport
Naidu.
Thats it!!  Thanks!  I did not have the port channel set and when I changed that the NIC's went active.  Thansk again for the quick reply!
