Policy Based Routing in Cisco 4506
dpatkins
We are wanting to run some policy based routing.  I have set up the route map, but when I attempt to assign the policy to the Vlan interface, it is not an option.
Is there an option that will need to be enabled prior to utilizing this feature?
We are using the following Version:
sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(25)SG, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 17-Aug-05 15:50 by alnguyen
Image text-base: 0x10000000, data-base: 0x1137CC08
Any help would be greatly appreciated.
Dwane
Amit Singh
Dwane,
The IOS you are running does not support PBR. You need atleast EnterPrise services to run PBR on Cat 4500 SUp's.Which Supervisor Engine are your running BTW?
Please see below featuresets supported on various IOS images on Cat4500.
Cheers,
-amit singh
Thanks Amit.  THat is what I was afraid of.
Our supervisor for this particular device is a:
1     2  Supervisor IV 1000BaseX (GBIC)         WS-X4515           JAE0934JQQV
Thank you for your help.
Dwane
Sorry but you have to upgrade the sup 4 to enterprise services to enable the PBR.
Good luck with that.
Cheers,
-amit singh
Hi all,
I have a similar problem.
My question is: is there an alternative to PBR for source based routing?
(I want to seperate guests from workers with VLANs and a didicated firewall interface, so I have to route guest traffic to the correct VLAN)
Thanks in advance!
Cheers
Phil
