Creating local admin on multiple switches
ahad311
Frequent Visitor
Frequent Visitor
Hello all,
Is there an efficient way to create a local admin on multiple cisco switches, instead of having to login to every switch to do so?
Can this be done using cisco prime? where you can create a local admin account and push it out to all the switches?
Thank You
Seb Rupik
Hi there,
This is a good use case for Ansible, take a look at this module: cisco.ios.ios_user module – Module to manage the aggregates of local users. — Ansible Documentation
If you don't fancy setting up Ansible (or simply running it from a container) then you good create a simple Python script to push commands to a set of devices. I always direct people to this as an example which you could expand upon: srupik-apic-em-tools/oneLinerSimple.py at master · sebrupik/srupik-apic-em-tools · GitHub
cheers,
Seb.
Jitendra Kumar
Yes its support..
Centralized visibility of distributed networks: Large or global organizations often distribute network management by domain, region, or country. Cisco Prime Infrastructure Operations Center helps you visualize up to 10 Cisco Prime Infrastructure instances, scaling your network-management capability while maintaining centralized visibility and control.
●     What is new in Prime Infrastructure 3.x?
◦     Cisco Prime Infrastructure 3.x offers new capabilities and a few are highlighted below.
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/datasheet-c78-735696.html
Jitendra
