Crestron NVX configuration - Catalyst 3850
mAjIk77
Qualifier:  I'm an AV guy.
I need help configuring a Cisco Catalyst 3850 for multi-casting / IGMP / Crestron NVX.  Using a SG300 in the past wasn't a problem because the web interface is very intuitive, I got things up and running in a day.  This 3850 is a whole different animal.  It appears I've got to configure this 3850 using line commands that are new to me.  Can anyone provide a succinct list of steps, or point me in the right direction?  Thanks!
JasonA.
I think you can access device manager via FindIT and change the config as required for your NVX network:
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/small-business-findit-network-discovery-utility/data_sheet_c78-570064.html
bdgarcia
Does anyone have any experience with configuring C9300 family of switches with the Crestron NVX family of devises?
Crestron NVX generic IGMP requirements
Crestron NVX general info
Hi, did you ever find information about this? I'm just having the same challenges and there seems to be very little out there.
