Cross stack etherchannel on catalyst 3750X with LAN Base feature set
Oleg Volkov
Dear Sirs
I will select switches for working in stack (without POE, and only two switches. I will use this switches only as L2).
Can I use cross stack L2 EtherChannel with LAN Base license?
Also, I need install C3KX-NM10G, and insert in to this module, SFP-10G-ER transceivers, I read I can use this transceivers with 15.0 IOS. It is true?
Thanks!
Helping seriously ill children, all together. All information about this, is posted on my blog
2 Accepted Solutions
Collin Clark
Yes you can Etherchannel with LAN Base and the ER transceivers are now supposed to work with 15.0 (have not had to do it yet though).
Leo Laohoo
As what Collin said, -ER is supported in 15.0(2)SE.
When you said "selected" did you mean that you HAVE NOT purchased the 3750X yet?
If you haven't, then I'd recommend you look at the 3850
Collin Clark
Leo Laohoo
