Cross stack etherchannel
saimunpial
hello,
in one of the data center we have presently six 3750G swithches in a single stack. Now we want to make a different stack with another two 3750 G switches which will be connected as etherchannel with the present stack. I have read the configuration from the cisco site that it must be done in LACP mode. But I have two questions regarding this issue:
1) is it possible to use 10 GB SFP uplinks ports to configure as etherchannel for cross stack?
2) LACP supports until 8 gbps full duplex. So if 10 GB SFP supports then I will configure in this manner that from the 2nd stack one of the sfp port from switch 1 will go to 1st stack  switch 5 SFP port and another from 2nd stack switch 2 to 1st stack switch 6. So every SFP will support until 8 gb. But my questions whether
3750 G support cross stack?
advance thanks for any assist.
Saimun
Ganesh Hariharan
hello,
Saimun
Hi Saimun,
Catalyst 3750 Series supports both CrossStack Fast EtherChannel and Cross-Stack Uplink Fast,Check out the below link for more information
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_qas09186a00801b0971.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
