CSS 11506 ADMINISTERING ISSUE
kvkrishna
Community Member
Hi ,
The CSS 11506 which was configured for redundancy for server loadbalancing was working fine till date.Its 2 days back that we were unable to open the http session for the virtual ip.ie:, the session stops after the home page itself.What could have been the problem.There has been no change in the configuration.
I have not configured the keepalive as of now.Is it required?
Jkannan
didyap
Level 11
Level 11
Configuring 'balance leastconn' would help to load balance CSS11506 properly.To specify the load-balancing algorithm for a content rule, use the balance command. This command is available in content configuration mode. Refer URL
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a0080117624.html#xtocid11
