current number of mac addresses in a catalyst switch
Ditter
Level 4
Level 4
Hi to all,
i am trying to recall a show command that shows current count of mac addresses in a catalyst switch (IOS). I am not referring to command "show mac address-table) but a command that shows how many MAC addresses are active on FastEthernet 0/3 , FastEthernet 0/4 e.t.c.
I issued this command in the past but now i forgot it.
Thank you,
Ditter
Joel
You have the following to find out per interface
show mac address-table interface fa0/1
Or you could use pipe to take the output from show mac address-table to the input of include and limit to interface
sh mac address-table | include Fa0/1
Finally, you have count for each VLAN
show mac address-table count
Joel
andresfr
Hello, are you referring to the following command?
show interfaces GigabitEthernet X/Y/Z mac-accounting
It requires the ip accounting mac-address to be configured at interface configuration level.
And the output is like this:
router#show interfaces GigabitEthernet X/Y/Z mac-accounting
GigabitEthernetX/Y/Z
  Input(494 free)
    0000.0c5d.92f9(58 ):  1 packets, 106 bytes, last: 4038ms ago
    0004.c059.c060(61 ):  0 packets, 0 bytes, last: 2493135ms ago
    00b0.64bc.4860(64 ):  1 packets, 106 bytes, last: 20165ms ago
    0090.f2c9.cc00(103):  12 packets, 720 bytes, last: 3117ms ago
                  Total:  14 packets, 932 bytes
  Output (511 free)
    0090.f2c9.cc00(103):  8 packets, 504 bytes, last: 4311ms ago
                  Total:  8 packets, 504 bytes
Thank you all for your replies,
i was looking for a single command  to provide all this info, for example in a catalyst 4500 with 192 ports it would be easier with one command to have the concurrent MAC addresses per port.
I finally recalled the way i did it in the past, but it is not so straight forward. First step is to activate port-security on per interface basis and then issue the command show port-security.
sw1#sh port-security
Secure Port MaxSecureAddr CurrentAddr SecurityViolation Security Action
(Count) (Count) (Count)
Gi2/21 10 1 0 Shutdown
Gi2/22 10 0 0 Shutdown
Gi2/23 10 0 0 Shutdown
Gi2/24 10 1 0 Shutdown
Gi2/25 10 1 0 Shutdown
Thank you all.
