09-06-2018 05:46 PM - edited 03-08-2019 04:06 PM
Hello world!
I do have the following question:
Will a trunk port with allowed vlans 1, 2 and 3 still send BPDUs of vlan 4 ?
The switch is a Nexus 5k and it's running pvst+.
Normally I woudl think It wouldn't, but im seeing them in wireshark.
Solved! Go to Solution.
09-07-2018 02:52 AM - edited 09-07-2018 02:58 AM
R1(config-if)#do sh int tru Port Mode Encapsulation Status Native vlan Et0/0 on 802.1q trunking 1 Port Vlans allowed on trunk Et0/0 1-4094 Port Vlans allowed and active in management domain Et0/0 1-4 Port Vlans in spanning tree forwarding state and not pruned Et0/0 1-4 R1(config-if)#
R1(config-if)#do sh int tru Port Mode Encapsulation Status Native vlan Et0/0 on 802.1q trunking 1 Port Vlans allowed on trunk Et0/0 1-3 Port Vlans allowed and active in management domain Et0/0 1-3 Port Vlans in spanning tree forwarding state and not pruned Et0/0 1-3 R1(config-if)#
I am not seeing BPDU's for VLAN 4 if it is not allowed on the trunk.
09-07-2018 12:51 AM
to my best knowledge, the only way to actually stop BPDUs being sent across a trunk is to use pruning. Otherwise, BPDUs are sent for each VLAN that exists on the switch...
