Data Center Routing Protocols
angel-moon
Level 3
Level 3
Hello all,
I have been told that running BGP inside a data center is not recommended.  I know its OK for WAN sites.  Can anyone tell mew what protocols should be used and why?
Thanks.  Replies rated!
Reza Sharifi
It all depends on your design and what you are trying to do.  If you are designing a data center with multiple tenants, than protocols like BGP, MPLS, VRF, etc... maybe necessary for segregating each customer.  If you are just designing a data center for a single agency, running an IGP like OSPF or ISIS is probably sufficient.
