Cannot remote into 1 of my switches.
brian_k_schmitt
Hello all I hope I have the right forum.
I inherited a network on site that has a Cisco ie3000 switch in a building I'm not cleared to enter yet. I can see the switch from and ajoining cisco switch but I cannot telnet, Hyperterm, SSH, or web interface into it. I will post the startup below omitting the IP but I know that is not the issue. Can anyone see what I am missing? I know it's not a hop issue as I am 1 hop away. Other switches in my network all can be accessed with no issues.
Switch#sh start
Using 969 out of 65536 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ptp mode e2etransparent
no mac authentication
mac authentication table version 0
spanning-tree mode pvst
alarm profile defaultPort
vlan internal allocation policy ascending
lldp run
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface GigabitEthernet1/1
 switchport mode trunk
interface GigabitEthernet1/2
interface Vlan1
 ip address ###.###.###.### ###.###.###.###
 no ip route-cache
ip http server
ip sla enable reaction-alerts
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Jon Marshall
Well there is no password set up under the VTY lines.
But usually you can't enter "login" until you set a password.
What error do you get when you try to telnet ?
Jon
No error just times out. I think I'm going to get an escort into the area and I will upload a modified known working startup into it.
