Data Port in IDSM
new_networker
Does the data port # refer to the actual port # on the switch ports. With the following configuration could you please explain what does 'Gi3/2, Gi13/d1' display mean in 'show vlan id 661'
router# show run | include intrusion-detection
intrusion-detection module 13 management-port access-vlan 147
intrusion-detection module 13 data-port 1 access-vlan 661
intrusion-detection module 13 data-port 2 access-vlan 662
router# show vlan id 661
VLAN Name Status Ports
661 ward-attack3 active Gi3/2, Gi13/d1
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
661 enet 100661 1500 - - - - - 0 0
Remote SPAN VLAN
Disabled
new_networker
Does the data port 1 refer to sensing interface GigabitEthernet0/7 and data port 2 refer to sensing interface GigabitEthernet0/8 ?
