Deactivation of WLC Features on Catalyst 3650
Hello Community,
I would to know if it is possible to deactivate the Wireless LAN Controller Features on Cisco Catalyst 3650? We don't need this feature and need to harden this device because of it's placememt in our network. I think it should be a perfomance factor also.
Best Regards,
Benjamin
Mark Malone
its off by default unless you enabled it this is the command that makes it active----wireless mobility controller
if you have set it up just use no wireless mobility controller to disable wireless functions
